Kodiaq Easy Entry
I noticed that some Audi and VWs with electric seats are automatically retracting when parked and ignition is switched off.
Is this a coding feature or something in the infotainment menu?
Edited by BGB
It can be coded to do easy entry....
The Carista dongle allows this - but - if you have someone behind the driver they can get squashed if not expecting it (legs) - especially on Karoq.
I did the wife's car and she was complaning to me Saturday about squashing her when she was sat in back next to granddaughter..
Thank you @Kenny R, could not find out the name for the function.
Do you happen to know the address in VCDS?
I had it on my Superb II, I guess it goes for a Kodiaq too:
36 – Seat memory drvr – adaption 10 – channel 60 Easy entry – value 1
Thank you so much @linni
@BGB
Double checked, for MQB goes:
STG 36
encoding
Byte 3, bit 1
On 30/09/2019 at 22:22, linni said:
@BGB
STG 36
encoding
Byte 3, bit 1
As far as I know, this activates Easy Entry permanently. To control it via menu, I switched byte 9 bit 6 in the same module.
This was in addition to what was previously specified!
Thank you but it did not work.
The car did accept the coding (both) but nothing happened, no movement in the seat nor anything in the menus. Where did I go wrong?
Edited by BGB
Typo
You have memory seats?
Also I remember when I received my car, the salesman fiddled something in the meny to assign the seat to the key.
Worked on my Superb II.
Yes I do have memory seats, however the key/seat feature is deactivated.
There should be (now) "Seats" menu in car setup, check option there.
Sorry. I forgot another part, to enable menus:
Address 5F, Adaptations
Car_Function_Adaptations_Gen2-menu_display_seat_configuration — Active
Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high — Active
Car_Function_List_BAP_Gen2-driver_seat_0x10 — Active
Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus — Comfort
This was already all active.
I got easy entry in the menus but no movement in the seat. I give up 😛
I think you need to activate the key / seat feature - otherwise it does not know where to move to...
Which above you said was not active.... I suggest you start there..
Program seat and key..
Edited by SimonAudi
Tried that as well, but thanks for suggestion.
@BGB
STG 36
encoding
Byte 3, bit 1
Just tested.
Seats option appears in car menu and Easy Entry box ticking enables the function.
Random question - does any of this ‘coding’ interfere with warranty?
id be paranoid about re-coding parts of the car and it causing some other damage and Skoda wriggling out of coughing up for warranty work.
All these codings are actually official features of VAG. You are just enableing them.
Never heard anybody had warranty problems due to VCDS tweaks.
Hi everyone,
Brand new Kodiak L&K.
Noticed thet easy entry seems to work fine.... however when I leave the vehicule and try to lock it via the small indent on the door handle... does not work most of the time.
It's been raining for a while here where I live, perhaps it has something to do with it?
Or should I just keep trying and if no success take it back to the dealership...
thanks for your help
You need to completely remove your hand from the handle and just touch indent from outside - yesterday - I tried locking mine with my hand still in the handle (not touching) and it would not lock..
Just a thought..
Just a thought..
Thanks for the reply. Actually when I lock the doors. (Or try to...) Hand is not in the handle anymore. Have tried to lock from passenger side and same issue...
indent is perhaps not sensitive enough.
  • 3 years later...
On 08.10.2019 at 19:19, Cavaler said:
Bildiğim kadarıyla bu, Kolay Girişi kalıcı olarak etkinleştiriyor. Menü aracılığıyla kontrol etmek için, aynı modülde bayt 9 bit 6'yı değiştirdim.
Bu, daha önce belirtilenlere ek olarak yapıldı!
Hi, menu appears under the seat screen for both the driver's seat and the passenger seat, but only the driver's seat works.  Is there another coding for the passenger seat?
Works for drivers seat only. Why would the passanger need an easy entry without having a steering wheel?
A feature implemented in the USA where the average driver is a little larger than the average European driver 🙂
