1st MOT - FAILED!!!! Grrrrrrrrrr
14 minutes ago, Roottootemoot said:
RE a Fail.
Strangely if you have the VED on Auto Renewal with the DVLA and MOT early and have a fail they still renew the VED.
Stop wasting time posting, you should be on your way round to pressure wash his shockers. Why you got the short straw nobody knows, but such is life.
I have had advisories about misting shocks after spraying Screwfix no nonsense penetrating oil under the arches. I however do not currently require your services with the pressure washer, If things change I'll be in touch. 😀
His shockers are shocking and no point gettig that dampers damper than they were.
There is a known fault with the shocks, ask them to look up the list of tpi. I was told this by a main dealer.
Edited by cheezemonkhai
