What model DSG is used in the Kodiaq with the 2.0 l/132 kW TSI engine?
Hi all,
Does anyone know what model DSG is used in the Kodiaq with the 2.0 l/132 kW TSI engine?  I'm just curious as the common DSG's used with small engines are not rated for the torque that this engine produces.
I may have found my own answer in a review article dated October 2018, which states:
"It's a DQ381 wet-clutch unit shared with the the Golf R, replacing the DQ500 previously used in the Kodiaq (mmm, model numbers)"
Review link: https://www.caradvice.com.au/670970/skoda-kodiaq-132tsi-sportline-long-term-review-city-driving/
My Kodiaq is a May 2019 build so I guess I have the DQ381, if they have their information correct.  I might grab an OBDeleven to double check for myself.
As of MY18, the 132kW/140kW TSI engine has the DQ381.
Mine was MY2019 and had DQ500.
Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
   Part No SW: 0DL 300 013 G    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2119
   Revision: 00H06V07
Hi wokwon,
Did you obtain that info from an OBDeleven?
2 hours ago, Gzed said:
Hi wokwon,
From VCDS.
Must be a carryover since we still get the 132TSI. The 140TSI has the DQ381.
