ABS ESP warning lights and fault codes
Hi all, i've got an issue with my 2012 octavia scout for some time Ive had an intermittent fault where the ABS ESP warning lights would come on this usually cleared itself but occasionally it required the codes clearing, however now the lights are on permanently, and i cant clear the  following codes:
  • 00283 - ABS Wheel Speed Sensor Front Left (G47)
    00283 - ABS Wheel Speed Sensor Front Left (G47): Electrical Fault in Circuit
    00283 - ABS Wheel Speed Sensor Front Left (G47): Open or Short to Plus
    00283 - ABS Wheel Speed Sensor Front Left (G47): Signal Outside Specifications
    Possible Causes
  • Open Circuit in Wiring from/to ABS Wheel Speed Sensor Front Left (G47)
  • ABS Wheel Speed Sensor Front Left (G47) faulty
  • Brake Electronics Control Module (J104) faulty
  • Possible Solutions
  • Check/Repair Wiring from/to ABS Wheel Speed Sensor Front Left (G47)
  • Check/Replace ABS Wheel Speed Sensor Front Left (G47)
  • Check/Replace Brake Electronics Control Module (J104)
Power Steering
  • 01316 - ABS Control Module
    01316 - ABS Control Module: No Signal/Communication
    Possible Causes
    • Wiring/Connector(s) from/to ABS Control Module faulty
    • Fault(s) stored in ABS Control Module
    Possible Solutions
    • Check Wiring/Connector(s) from/to ABS Control Module
    • Check Measuring Value Blocks (MVB)
      • Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
All wheel drive system
  • 00625 Vehicle speed sensor
Has anyone come across this issue before ? or able to give me any pointers?
Thanks in advance
I'd suggest checking the front left abs sensor, it's wiring and also the reluctor ring.
Hi, sorry i should have said Ive replaced the LHF wheel sensor, i couldn't see a reluctor ring, is it part of the drive shaft?
I know the rear reluctor rings are built into the hub but I'm not sure about the fronts.
@Tech1e - might be able to offer some advice.
