Bolero cutting out
Hi,
I have a 62 plate Yeti with a Bolero unit, (don't know what version, but it has CD, SD, Bluetooth and mobile phone).
When playing the radio, the unit intermittently cuts out, but it doesn't do it when playing from the SD card, CD or Bluetooth.  Hence, I'm thinking it's a reception problem, so any ideas where it is most likely; connections at rear of head unit, aerial connections in roof, control module under driver's seat or elsewhere?
Coincidentally, the mobile phone doesn't work properly, as the microphone isn't active.  Is this likely to be part of the same problem or something different?
TIA
Does that only happen on DAB, FM or AM? Or a combination?
I'd probably check the roof antenna for water ingress.
PetrolDave; Don't have DAB and there's no AM reception to speak of in amongst the Welsh hills, so I only use the radio on FM .  However, it cuts out on all stations, so it's not just a case of moving from one frequency to another.
