Date display?
I have a standard spec SE L (other than It has a fitted tow bar).  Is there anywhere in the various display screens where it shows the date?  Not the end of the world if it doesn’t of course, but I do find that a useful bit of info to have to hand.
It's top right on the central display when the engine isn't running. When it's running, that location is used to show the driving mode and gear number (e.g. D6 or M4).
Edited by agedbriar
Thanks.  So nowhere when it’s running?
Not to my knowledge.
When you turn on the ignition, assuming the Infotainment system is switched off, the Skoda logo will be displayed on the Infotainment screen briefly, and is then replaced with the clock display.  The date displays below the clock briefly, before disappearing.  It's possible to redisplay the date by waving your hand near the bottom of the screen (there is a movement sensor which brings up menus in the various Infotainment features), always assuming the Infotainment system is switched off.  If it's switched on, there is no date display.
When you turn the ignition off has at top of informant
