Help with geometry settings with B12 kit
Car is an 06 vrs estate
3 years ago fitted B12, had geo set up and no issues with asymetrictyres
Year ago fitted Michelin cross climate + tyres
Tyres started roaring  shi geared saw toothing and used standard recommended settings for a VRs as stated on here
Year later Tyre roar still there and louder.  Just spoken  to a Tyre technician looks like geo is still out as tyre looks like it's getting hot and the sipes are wider than expected
I will get suspension checked by trusted mechanic first, then redo alignment and tracking
So anyone with similar setup reccomend settings as perhaps std isn't right for the B12 setup
Thank you in advance
The only tip I recall to reduce sawtoothing is to reduce the rear camber as much as possible but keep it just in spec.
Happy to be corrected by others though.
Thanks Langers
Tbh I had the sawtooth issue with the rear tyres on mine and also a loud roar and had it hunter 4 wheel aligned and I've never had an issue with it in 2yrs, 👍🏼
