MFD (Mult Function Display) Issue
So the Right Hand thumb Wheel is rotating ok backwards & forwards but the display for avg consump, mph,range etc.... will not show when turned with it.
Sometimes it will turn 1 cycle to the next only on after starting the engine.
Anyone know how to fix? Its a Mk3 2016.
Sounds like a faulty roller.
I had a faulty scroll wheel in my Superb but with mine it was scrolling OK but wasn't doing anything when you pressed the roller in to select.  I'd say it'll be a quick replacement of the right hand side controls under warranty (If you're still in warranty).
Same happened on my 2016 Fabia,it's a known problem .
think we are out of warranty now not sure nought car in July 2017 already a year old, how much would cost local garage if i can find the bits, i presume the steering wheel has to come off
No idea on price I’m afraid. From memory it’s just a case of the controls on that side being removed from the steering wheel and the new ones fitted. The steering wheel shouldn’t have to be removed.
Mine was done by the dealer while I waited if I remember correctly.
