Towbar
Thinking of fitting a towbar to my 2011 roomster 1.2 tsi. Will this interfere with my parking censors. And what type would you recomend a flange , swan neck or detachable towbar
Hi David, I
have a flange type, very small cutout at bottom of rear bumper. No interference with reverse sensors. I had 19 pin wiring which integrates with canbus and shows a trailer when I select reverse (If I'm Towing)
I take it the reverse censor doesnt come on when a trailor is hitched
  • 4 weeks later...
On 04/12/2019 at 16:41, bryanb said:
Hi David, I
What make was your towbar
Sorry, can't remember. But it was supplied by an independent fitter. Wirng loom ws a seperate order. All in  supplied and fitted and registered to canbus £450 +  or -
Just shows a generic picture of a trailer when reverse selected if towing.
Edited by bryanb
The fact that the radio display shows a trailer on the screen suggests that the towbar has been installed correctly. In that the fitter has used a bespoke module and correctly coded it so that it integrates to the cars systems properly...
- Rear parking sensors deactivated.
- Rear fog light on the car deactivated.
- Alarm activation if electrics disconnected and the car is locked.
- Electronic Stability Control (ESC) is adjusted to reflect that there is a trailer connected.
- Satellite Navigation avoids narrow roads or restricted routes.
- Bulb monitoring system extended to check the trailer lights, and the indicator buzzer is replaced by a secondary green light on the dash.
Plus more.
The fitters that simply splice into the cars wiring loom are best avoided.
