What is the correct code for 55-Headlight Range
Hi guys,
I'd like to know the correct code for the Headlight Range (5M0 907 357 C - SW 136) that activates the front & rear leveling sensors in my mk2 FL. My current code is 1507354. I also would like to know if the headlight projectors react to the steering.
Thanks!
I have the same controller version but software 0142.
The same coding also.
You have to enable the bending function in through your MFD display under the assistance menu.
Then the projectors do start bending in speeds over 15km/h, but not much, it is also dependant in vehicle's speed and steering angle.
So, the aforementioned code enables the leveling sensors?
Yup. Should be correct for standard functionally in a stock LHD car.
You can check what's working by logging the headlight positions, steering angle and speed whilst you drive.
