help please
cam anyone tell me why my 1.6 1997 felicia wont rev over 3000rpm or go past 70mph? It was going fine but my thermostat stuck shut i stoped before it got 2 hot it now has no stat in the car is this why it wont run rite because it had no thermostat in it when i got the car last week and they put 1 in at the garage wich the aa have took out if any1 can shed some lite on this problem it would help many thanks nathan
:) Obviously it's hard to diagnose faults without seeing the car..but I reckon the catalyst may have collapsed and is blocking the exhaust. I've seen this many times on all sorts of cars in the garage I work in. I can't think how a thermostat fault could prevent the engine from revving, unless the car has gone into a "limp home" mode. Maybe the ECU has gone into this mode thinking that a coolant sensor is faulty? There are loads of possible causes of your fault,and if the exhaust/catalyst isn't blocked you'll need to get the ECU fault codes interogated.
Sorry to seem vague, just a few thoughts that may help,or may not!:thumbup:
The problem runing with no 'stat is the engine just doesn't get warm and thus doesn't get off cold start, it also confuses the coolant temp sensor.
I'd get a new housing complete with a new sensor (only about £30-£40) put that on and go from there.
p.s if you want help it might be worth taking some time and typing properly with punctuation etc, had a hell of a time reading that.
Ross
