What can we swap over from a mkI?
Hi,
I have a 2005 MK1 1.2 Skoda Fabia that needs scrapping.
My friend has a 2008 MK2 1.4 estate that doesn't need scrapping
We're going to take the good bits off mine before it goes to the scrap man - is there anything that doesn't match that we'll (besides the obvious)
Specifically, will we be able to remove the front exhaust inc cat and flexi and pop it over (his has a hole which is an expensive fix) ?
Mine has a new battery and new discs and pads, assuming these are fine to swap/use as spares also?
Will
Exhaust (any parts) - Almost certainly not transferable.
Battery - Check physical dimensions and power capacity. If the physical dimensions are the same and the capacity is the same or greater that'll work.
Discs - Unlikely; check the PCD which should be the same for both cars. If they have the same PCD, check the overall size and centre spigot as well.
Pads - depends on the calipers.
Thanks for the reply, quite surprising the lack of transferability given I'm used to taking old parts from everything else in the vag group!
Seats fit if you had leather.
Many controllers are different architecture.
