Boot light bulbs!
Hi guys. Wonder if anybody can help me. I got some canbus error free interior bulbs including the boot, 1 out of 6 worked😡 so I put the old bulbs back in and apart from the boot lights there all working which doesn’t make sense as they were fine before I attempted to change them. Has anybody else had this before at all? Any advise I would appreciate
LED bulbs can only work one way round.
Have you tried them the other way round?
Thanks AG Falco
I have yes and still nothing😡
I swapped my bulbs for LEDs and they all worked just fine. Where did you get them from?
I got them from eBay £8 for 8. I’m thinking could it be a fuse that’s blown but then why would changing bulbs blow a fuse!
Most likely not a decent quality?
Common with 'Chinese' bulbs of a kind of noname..
Could well be but for the price I thought they were ok?! Just don’t know why my original bulbs don’t work now!
If the ones that don't work now share a circuit...
Go to Superskoda.com for your LED light bulbs....they are frankly brilliant and you never have any issues.  They cost about £16 a bulb....you pays for your money....
@Dan13 The boot light bulbs do not need to be CanBus friendly........I don't think the interiors do either IIRC
I fitted these.....https://www.ebay.co.uk/itm/6X-12V-Led-Strip-Drl-Daytime-Running-Lights-Fog-Cob-Car-Lamp-White-Day-DrivingUK/333232004067?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
On either side with one above the parcel shelf and one below, fitted on the pillar above and stuck to the plastic corner below, with a switch on this side replacing the original fitting.
Loads of light.
Edited by Tilt
Cannot find the ones i purchased for roof lights (front and rear) but something like these
I even stuck two of them together, making sure that the end connectors were touching, to give me double the light in the front.
These have been in the car for few years now without issues.
Boot lights were fitted last year.
Edited by Tilt
Ah ok I didn’t realise they didn’t need to be canbus I think il have a look at super Skoda n order some. I did buy some cheap ones around a year ago without any issues but didn’t think they were bright enough hence me buying these ones now that don’t work n were more money!😡
