Cheap VCDS
has anyone purchased these cheap VCDS's from ebay? -
I had a message from a seller saying it's the same as rosstech:
it will work with pretty much all VAG cars from 91-18. please see attached picture for cable you
We list like this as ross tecch do not like people selling these cables are way lower prices than them.
VAG COM VCDS DIAGNOSTIC TOOL WITH GENUINE SOFTWARE
THE ONLY DIFFERENCE BETWEEN OUR CABLE AND THE ROSS TECCH IS YOU CAN USE ONLY THE SOFTWARE THAT WE SEND YOU WITH THE CABLE. WHICH WIL BE VERSION 19.6 WHICH COVERS ALL VAG CARS UPTO 2018
BRAND NEW
READ/ERASE ERROR CODE, PROGRAM, CODE, DPF REGENS AND MUCH MUCH MORE
FULL- VERSION - FULL FEATURES - UNLIMITED USE - UNLIMITED VINS
FULLY REGISTERED UNLOCKED 2018 VERSION
UK STOCK "
I'm interested in priming fuel pump/fuel filter/ fuel rail when messing around with the fuel system.
P.S. turning on and off the ignition doesn't do it for me, I broke an ignition switch and made a messed with the fuel lines when trying to prime a stupid fuel filter.
Edited by john999boy
Link removed
Most likely a cheap foreign import that will do more harm than good.  You can really f***  up your car with one. Genuine Ross tech VCDS is around £250/£300 I believe, the clue is in the price.
Briskoda doesn't allow the discussion or condone the use of fake cables due to copyright issues and other potential problems.
thing is, I didn't want to spend that much for occasional use 😞
i didn't know it was fake... hence why i'm looking for advice
Guest
