Fabia vrs diesel oil
After looking on Briskoda at a few oil threads i made a little list of 4 or 5 oils i thought would be easy to get. These included:
esso
shell
castrol
BP Special
and some other ones
I headed down to the BP garage but they had no oil for the fabia Vrs, same story at the shell garage and esso.
I then went to Halfords and i found one !!!:thumbup: Castrol Edge Turbo diesel 5w-40 505 01 approval for VW engines including PD engines (fully synthetic)
I bought 1 litre for
i'm sure the castrol oil at the correct VW spec will be OK for your car , i use FORDs own oil for the Galaxy thats the correct spec and not encountered any problems
thanks
just being a bit cautious, dont want to do anything to the engine :)
Check out Comma PD Diesel, normally available from most motor factors. Mine down here in Dorset will do 5L for
There is a complete list of the current known oils compiled by Denis on my website.
I'll add that one in then, thanks Richard.
oil specification is correct and castrol are a good name so i wouldn't hesitate in using the oil you bought to top up the level
i'll use it shortly to top up. thanks for all your answers.
It's now on the list :thumbup:
My VRS is on 48,000 miles now ( 04 plate ) used millers pd semi -synthetic ,on every service, not a problem and conforms to all the manufacturers specs
Im using Mobil 1 synth s special v and i think it's great, almost 40k miles and minimal oil consumption. It's arround 7£/liter
