driveshaft splines lubricant
Hi. Does anybody knows what happens when you put grease (liqui moly langzeitfett lm47 mos2)nstead of oil on the splines of the outer end of driveshaft and the hub. Should i remove the whole thing and refit with engine oil as described in haynes manual, or will do the grease fine as well.
Should be fine, I‘ve just use grease or copper slip in the past without issue 👍
On previous cars I used copper grease with no I'll effects.
Thanks ! Than stays with grease.
