Full LED matrix turning or not?
Do the Full LED Matrix lights turn as the road curves?
The LED module won't physically move like the AFS xenons used to. Instead, it'll turn on/off some LEDs to light up the inside of a corner although I'm not sure at what speeds it'll work at.
You can see both extra LEDs around the 50 second mark. The first is just under the headlamp and the second is the fog lamp:
Are you sure the LED lights don't move? Can't check now but I'm pretty sure mine do at least a down-and-up when they're turned on, if not a left-and-right like the HID lights used to do...
(but for cornering it definitely does light up extra LEDs)
Sorry - I wasn't super clear.
Yes, they will move up/down for automatic range adjustment. They won't move left/right for cornering use like the older 'bending' xenons did :)
Thank you for the clarification!
There's separate "cornering lights" that turn on when turning at lower speeds, watch this video:
