CODE P308D00
Hi Guys
Had this code high pressure fuel pump changed the pump ( done the belt at the same time ) not cured the problem have also renewed the fuel pressure sensor on the rail not cured last option fuel pump in the tank don't want to go to much more expense anyone has this problem also stop start error no codes reading hope its all connected
THANKS
Thanks Gabbo will look into it it's sometimes best to take advice before jumping
  • 9 months later...
I have the same issue, car gives the glow plug light intermitting in dash, sometimes in limp mode.
got it read for fault codes code 10064, according webpages the same as P308D.
reading this topic i see the same problems i have.
got already fuelfilter replaced.
what should i do next? see that the pump control module and pump needs to be replaced, but wanna be shure that the issue is over as cheap as possible.
please feedback.
