oil leak
Hi,
I hope someone can help.
I have an oil leak on a rusty steel pipe on the back of the sump. The pipe is between the sump plug and the oil sensor.
What is the name of the pipe (ie vent etc.) and where could I buy a replacement.
been searching on line but cannot find a diagramatic showing said pipe.
Bryan
Is the car diesel or petrol?
Do you know the engine code?
petrol 1.8 180 HP
engine no:-  AUQ015304AUQ
10 minutes ago, Bryan.Kelly said:
petrol 1.8 180 HP
You didn't mention the model year but the parts diagram for a 2004 AUQ engine is here.  I can't see your tube, can you?
its a 2001.
cant see it either 😞
found the 2001 AUQ and cant see it either HMMMMMMM.
I shall take a photo tomorrow.
That should be the turbo oil return pipe,  and is usually listed with the turbo on the parts diagrams.
This one, then?
Yes, should be parts 9,10 and 24 to do the job.
