How to remove acc radar cover
Love the graphics ;)
Why did you need to do this?
Edited by digifish
I'm retrofiting a5 camera, an i needed to know if there was 2 cables atached to them they arent there..
this is brilliant I have been searching high and low for a method of taking that cover off
I'm also retrofitting the a5 camera now and upgrading my radar also (for pACC), so the 2x twisted orange CAN wires need to go from the camera to the radar, right? How did you get through the firewall? Is that a hard cable run to do?
Hello did you replace the windshield ?
If you need any help fallow this  thread
Their is a tiny 1cm ruber  behind the clutch pedal , you will have to remove the battery and you catch the cable there.
20200414_085935_copy_567x1008.thumb.jpg.61a56664798e8d815204280b65dd4c62.jpg20200414_090039_copy_567x1008.thumb.jpg.688287bf32ffcaed1e3ce37883184001.jpg
Edited by Camarao69
thanks for that - yes i fitted the camera version windshield last week and have the camera mounted, just need to run the wiring harness and do flashing/paramaterising/coding/adaptations
  • 3 years later...
well i could not do anything i have a car diagnostic tool ob11 connected to try to look at the acc radar fault i have no cruise control just a red triange on the dash it said no faults found
so nothing could be adjusted i am at a loss i dont need the radar on the grill yes the brackets were broken i used 2 large tie wraps to hold it back in place
On 10/04/2020 at 04:09, Camarao69 said:
Didn't find anywere so as the title says here is how  to remove acc cover
Remove these caps.
Put a screwdriver in to the hole press it and push forward.
Acc radar.
Are those rivets?
Are they reusable once you take them out?
Taking them out just with some screwdriver under them and carefully pushing them up?
As a last question, is the radar fixed in that plastic mount with screws or something?
Thank you!
On 10/07/2025 at 06:59, Codrut20171 said:
Are those rivets?
Thank you!
No, they r not rivets.
They're plastic caps that push out and reusable.
Just pull it out carefully.
The radar itself is fixed in place by "calibrated" screws. i.e. mess with those, or the bracket and ur ACC will b out of whack and require recalibration!!
Ye I’m swapping to 3QF radar and wanted to know if I can just take out that cover and not the whole bumper in order to be able to change the radar. And also, do I have to move the plastic mount when taking out and mounting the new radar? Some guys told me it isn’t necessary to calibrate it (just the dynamic calibration) when changing the radar so I’m assuming I don’t have to move the main plastic mount.
Thanks in advance!
skoda superb se 2016 my car has only done 37000mls i have had it from new its now 9 years old yes i went to arnold clark for the repair kit it cost 48 pounds looked up utube for guidance to fit the repair kit it was not easy on my driveway put on knee pads and used a torch there were 4 bolts visable only two hold on the bracket for acc carrier so i fitted the repair kit put it all back together and fitted the front cover drove for most of the day reset the cruise control on the stock i was wondering about getting it recalibraited but now the fault has gone and is working just by fitting the repair kit for my car relief
  • 7 months later...
Thank you
I've also got the problem that I can't find any information on how to remove the ACC front cover for the superb 2020 onwards facelifted model. As per the picture given above there are no two holes to stick a scredriver into.
The front ACC cover is definately a seperate panel that I can see looks like it should clip off..... but I really dont want to break it.
Any ideas or links would be amazing as I really like to check there isn't grot on the inside which is stopping my ACC from working before paying the Skoda garage!
cover looks like it would be this one:
3V0853655D 041 Front ACC Radar Cover Škoda Superb 3 facelift
SKODA SUPERB MK3 Front Bumper Trim 3V0853655D041 NEW GENUINE - Picture 1 of 9
SKODA SUPERB MK3 Front Bumper Trim 3V0853655D041 NEW GENUINE - Picture 2 of 9
SKODA SUPERB MK3 Front Bumper Trim 3V0853655D041 NEW GENUINE - Picture 3 of 9
found this on eBay
Skoda Superb 4 ,2020-2023  3V0853655B 3V0853655D radar cover ,grill cover - Picture 5 of 8
Hi @Camarao69 ,
I am planning to remove this cover on my 2019 Karoq. I am guessing that after removing JUST the cover I will not have to calibrate the RADAR again, right?
My understandin is that unless you know it or the housing you shouldn't need to recalibrate it, but I'm definately no expert!!
For interest do you have hte two lug holes to insert screwdriver for releasing the ACC cover or like me with no holes and stuck on how to remove it!
I do have the 2 screw holes but I don't think there is a cover there, I believe that for me, in order to access the radar, I need to remove the entire grille.
Searching over the ethernet, I found no radar cover for the Karoq, only for Kodiaq 😔
For me, I want to remove this cover just to be able to mount a front parking camera and I want to make it look like OEM but I think I have to remove the entire front grille.
