Cental locking puzzle!!!!!
Have just bought 2012 Fabia 1.6 tdi.  Had it about 2 months.  Yesterday I noticed when using the key fob , the drivers door did not lock, but all the others , and taigate did.  If I use the key, evrything locks, but if I use fob to unlock, all open, except drivers door, which has to done using a key???? Any idea's????
Hello Matty
Worth having it scanned for fault codes, although I'd take a punt at damaged wiring from the door to the 'A' pillar, or dry joints in the door lock control module (PCB in the door lock being a bit brittle and breaking down over time with all the door closing and opening).
Gaz
Cheers Gaz. Will investigate
