Alan444
Hi  My windscreen wash is not working. The pump is ok. No reading on a multimeter. The fuse is ok. Could it be a relay and if so where is it and how easy is it to get at and check?
      Thanks for any help.
hi, is the pump running but no fluid coming out, or.. nothing happening at all.
id wager theres gunk in the stalk stopping the contact from being made.
spray a dose of electrical contact cleaner in there, and give it a good work oit as a first easy try.
The pump is fine. You can't here anything when you operate the stalk. When I press the button on the stalk to spray the screen
the wipers operate ehich suggests the stalk is operating successsfully. However I tried using a cleaning spray on the stalk and
unfortunately it didn't make any difference. Does this point to a relay problem
