Back Windows and Locks no longer working
Hi, any help.....back electric windows both sides, plus central locking both sides and the 12volt not working. Thought it might be the door loom but that looks ok. All fuses look ok. Any ideas??
almost certainly the wiring has fractured in the boot from a pillar to drivers door
Ok, follow on from the original post - had a few issues to resolve, clock ring replaced and used Carista to clear the codes. The faults with codes  to come back are below - the wires in the door loom look to be a little fractured so they've been checked and look ok - when you say the wiring has fractured in the boot from a pillar to drivers door where do you start with that??
These are the errors -
Central electronics
Part #: 1K0937087R
Component: BCM PQ35 H+
Coding: 40010AB8E00508C040080080310081E4437000AE436D85605C81C7000041 (hex)
Fault codes:
01333 Door Control Module: Rear Left (J388)
01334 Door Control Module: Rear Right (J398)
00979 Lamp for Low Beam; Right (M31)
01500 Bulb for Fog-Lamps, Right (L23)
Body/convenience system
[ECU not present]
Driver's door
Part #: 8X0959793E
Component: TSG FA
Coding: 011D0220D001001000 (hex)
Fault codes:
01332 Door Control Module: Passenger Side (J387)
Front passenger's door
Part #: 8X0959792E
Component: TSG BF
Fault codes:
01331 Door Control Module: Driver Side (J386)
Central electronics
Part #: 1K0937087R
Fault codes:
[ECU not present]
Driver's door
Part #: 8X0959793E
Component: TSG FA
Fault codes:
Part #: 8X0959792E
Component: TSG BF
Fault codes:
The wires can crack/break inside the insulation so a visual check is not enough. You'll need to probe them one by one with a continuity tester to check it properly.
Did all these errors occur at the same time?
It would be quite a coincidence for wires in 2 doors to go simultaneously.
Have you checked fuses?
drivers door control module is master powering all other doors (Slaves)
As above.  Take door card of and do end to end continuity
Find what wires are broken then repair with  extra 2 inch piece of wire to stop it happening again
simples
Fuse 32 supplies both J388 and J389.
There is no J398 in my copy of the wiring diagram.
Same problem happened to my superb.
Found 2 broken wires in rubber boot in drivers door hinge. Extra wires soldered in, bit fiddly but all sorted.
