Rear discs and pads
Hi,
Need to replace rear discs and pads, any recomendations what/where to buy. Original parts terrible, should I be looking at the likes of Brembo?
Thanks.
8 hours ago, kindalen said:
Hi,
Thanks.
I fitted Delphi to mine, bought at local independent motor factor,  not expensive but much better than original!
Brembo make high carbon discs and matching pads, will not rust as much as OEM
Demon tweeks can supply.  You can go on Brembo web for part numbers.
Mayoboat
Have fitted both Pagid and Brembo from ECP and both have shown signs of surface rust so would avoid those if that is an issue.
You must use the premium Disc from Brembo and pads.
Edited by Mayoboat
spelling
