Best alloy wheel cleaners
Hello!
Can anyone suggest a product to clean my Yeti alloy wheels, and any other tips re wheel cleaning?
Thanks!
KG
Bilt Hamber Auto Wheel` is a goodun.
Does a fab job of cleaning the alloy as well as removing the embedded metal particles as it turns a reddish colour.
Tried ez foaming wheel cleaner the other day. Worked well. Then used ez iron remover (can't remember the name) which also did a great job. If the bilt hamber stuff does cleaning along side iron removal it could be a good time saver if not using iron out on the body.
Bjilt hamber is the best'.  Apparently wonder wheels colour (not the older acidic one) also does well in tests and is ph neutral but ive not found it as good as the Bilt Hamber
