Skoda Kodiaq Electric Window Fault
I've posted about this issue before, but it is now getting slowly worse to the point it's becoming irritating. I reported it to the dealer at the last service and they claimed the usual 'no faults found' and that the module that powers the windows is simply taking time to boot up.
It is now at the point I'm not happy with it and want it rectifying. Simply out of curiosity does anyone else suffer or has suffered with the same issue?
It isn't easy to film the window and switch at the same time, but essentially despite pressing and holding the button the window will only partially drop, often in centimetre increments.
It is only after first starting the engine, and after a few minutes things will return to normal.
I have found that pressing the rear window lock-off button will (sometimes) instantly cure the issue.
Thanks.
My Golf R did this, it was remedied by getting a replacement switch panel.
Thanks, I've spoken to the dealer and booked it in (almost a month away), I also made it clear that I aren't driving all the way to them for them to do the same diagnostics and provide the same 'no fault found' response.
After sending them the video they've promised to order up some parts after speaking with Skoda Technical, I'll mention the window switch panel before I go.
