Fit switch next to gear lever
48 minutes ago, numskull said:
Make what.... an omelette? Sorry, couldn’t help myself!
Push to make switch = electrical circuit is open (off) until it's pushed
Push to break switch = electrical circuit is closed (on) until it's pushed
I didn't choose the #nerdlife, the #nerdlife chose me. 🤓
Well, that’s what they do. However... what are you going to operate with the switch? I ask as although you can buy the switch units, as far as I recall, none of these positively lock on or off, so depending on what you’re going to use it for, they may not be suitable.
I'm keen on doing this too, but in my case to operate my garage door opener.
A number of Golf owners have done this by buying a additional button to use in a blank spot, and then wire up the garage remote to it.
I've removed the existing switch panel to see how it all hangs, and it appears they share the same "backbone" to interface with the car.
So adding another button to the existing loom will b tricky.
However adding another button, wired up separately might b possible.
IMG_27072020_075034_(1080_x_1440_pixel).thumb.jpg.f742099efb0557c3ff91b0d4395ad210.jpg
IMG_27072020_075104_(1080_x_1633_pixel).thumb.jpg.c28b3c2f205acb68153a05fb38b0ccdb.jpg
IMG_27072020_075048_(1080_x_1481_pixel).thumb.jpg.4ff54991b1ddd13872f0306922ee15c3.jpg
On 27/07/2020 at 08:57, MartiniB said:
how to add custom button, step by step in pictures
-> https://www.drive2.ru/l/561347141419663661/
Thanks for the link with the info on adding another switch. I want to use it to open the rear hatch lid. I have already ran  the 2 wires required into where the switches are next to gear lever. It’s a pity we don’t have Maplin anymore. I will use Ali express.
