Octavia sdi front springs
Hi all , I have had my Octavia sdi just over a year & in this time I have noticed the front end being a bit soft. The shockers seem to we working fine as when I push down on car they come to rest after 1 bounce however the front seems to be sitting a bit low & on a couple of occasions hitting a pot hole it has made a thudding sound as if the car is bottoming out. Has anyone else come over issues with front springs on there Sdi & could recommend any make I'm currently looking at bilstein ones. Car has very low miles 45,000 your help will be greatly appreciated cheers colin.
The gknautomotive.com online catalogue lists OEM part number 1J0411105AD as being suitable for front springs on a hatchback or estate version of the Skoda Octavia MK1 1.9SDI.
https://web.tecalliance.net/gkn/en/parts/1/55064/detail?query=1J0411105AD&numberType=1&oe=1J0411105AD&groups=188#@brc/search:Search%20by%20any%20number%201J0411105AD;mandator:gkn;query:1J0411105AD;groups:188;brands:1;pf:2;page:0/detail:55064;brandId:1;articleNo:55064;mandator:gkn;query:1J0411105AD;numberType:1;oe:1J0411105AD;groups:188
Front springs with OEM part number 1J0411105AD have 1 white dot and 1 violent dot.
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2002/drive_standart/252/hg_ug/411/subcategory/411000/part_id/2561497/lang/e
Sachs 997614
https://www.ebay.co.uk/itm/2x-Sachs-997614-Front-Suspension-Coil-Springs-A3-OCTAVIA-GOLF-LUPO-POLO/223666942651?hash=item341396b2bb%3Ag%3AXkUAAOSwCgJdf1P3&LH_ItemCondition=1000
https://www.autodoc.co.uk/sachs/1233434
Suplex 03130
https://www.ebay.co.uk/itm/Suplex-Coil-Spring-Front-Axle-OE-Quality-03130/292040906024?epid=249107353&hash=item43fefe9528:g:AM0AAOSw4A5YtZ2x
https://www.autodoc.co.uk/suplex/8604453
The gknautomotive.com online catalogue lists OEM part number 1J0511115AM as being suitable for the rear springs on a Skoda Octavia MK1 1.9SDI hatchback.
https://web.tecalliance.net/gkn/en/parts/1/56652/detail?query=1J0511115AM&numberType=1&oe=1J0511115AM&groups=188#@brc/search:Search%20by%20any%20number%201J0511115AM;mandator:gkn;query:1J0511115AM;groups:188;brands:1;pf:2;page:0/detail:56652;brandId:1;articleNo:56652;mandator:gkn;query:1J0511115AM;numberType:1;oe:1J0511115AM;groups:188
Spring Design Coil spring with constant wire diameter
Fitting Position Rear Axle
Colour Coding Silver, Green (3x)
Thickness 11,00 mm
Length 343 mm
Outer diameter 112 mm
Weight 1,60 kg
Rear springs with OEM part number 1J0511115AM have 1 silver dot and 3 green dots.
Sachs 996618
https://www.ebay.co.uk/itm/2x-Sachs-996618-Rear-Suspension-Coil-Springs-TOLEDO-OCTAVIA-RAPID-BORA/223668571232?hash=item3413af8c60%3Ag%3AqWoAAOSwWspdgJ7S&LH_ItemCondition=1000
https://www.autodoc.co.uk/sachs/1232466
Suplex 39192
https://www.ebay.co.uk/itm/Fit-with-SKODA-OCTAVIA-Rear-Coil-Spring-39192/392384989331?hash=item5b5bf7c893%3Ag%3AuvMAAOSw3ItdVrUK&LH_ItemCondition=1000
https://www.autodoc.co.uk/suplex/8313922
OEM part number for Skoda Octavia MK1 1.9SDI hatchback heavy duty rear springs
1J0511115CF
https://web.tecalliance.net/gkn/en/parts/1/56653/detail?query=1J0511115CF&numberType=1&oe=1J0511115CF&groups=188#@brc/search:Search%20by%20any%20number%201J0511115CF;mandator:gkn;query:1J0511115CF;groups:188;brands:1;pf:2;page:0/detail:56653;brandId:1;articleNo:56653;mandator:gkn;query:1J0511115CF;numberType:1;oe:1J0511115CF;groups:188
Colour Coding Green, Brown (2x)
Thickness 11,50 mm
Length 360 mm
Outer diameter 110 mm
Weight 1,90 kg
OEM part number for Skoda Octavia MK1 1.9SDI estate rear springs
1J0511115AE
https://web.tecalliance.net/gkn/en/parts/1/56295/detail?query=1J0511115AE&numberType=1&oe=1J0511115AE&groups=188#@brc/search:Search%20by%20any%20number%201J0511115AE;mandator:gkn;query:1J0511115AE;groups:188;brands:1;pf:2;page:0/detail:56295;brandId:1;articleNo:56295;mandator:gkn;query:1J0511115AE;numberType:1;oe:1J0511115AE;groups:188
Colour Coding Green (3x), Silver
Quantity 2
Thickness 11,25 mm
Length 350 mm
Weight 1,75 kg
OEM part number for Skoda Octavia MK1 1.9SDI estate heavy duty rear springs
1J0511115AF
https://web.tecalliance.net/gkn/en/parts/1/56296/detail?query=1J0511115AF&numberType=1&oe=1J0511115AF&groups=188#@brc/search:Search%20by%20any%20number%201J0511115AF;mandator:gkn;query:1J0511115AF;groups:188;brands:1;pf:2;page:0/detail:56296;brandId:1;articleNo:56296;mandator:gkn;query:1J0511115AF;numberType:1;oe:1J0511115AF;groups:188
Quantity 2
Thickness 11,25 mm
Length 352 mm
Weight 1,70 kg
Edited by Carlston
Fitting Position Front Axle
Colour Coding Deep Pink, White
Thickness 12,00 mm
Length 350 mm
Outer diameter 140 mm
Weight 2,00 kg
Sachs 997614
Suplex 03130
Thickness 11,00 mm
Length 343 mm
Weight 1,60 kg
Sachs 996618
Suplex 39192
The gknautomotive.com online catalogue lists OEM part number 1J0511115CF as being suitable for the Skoda Octavia MK1 1.9SDI hatchback heavy duty rear springs
Thickness 11,50 mm
Length 360 mm
Weight 1,90 kg
The gknautomotive.com online catalogue lists OEM part number 1J0511115AE as being suitable for the Skoda Octavia MK1 1.9SDI estate rear springs
Quantity 2
Thickness 11,25 mm
Length 350 mm
Weight 1,75 kg
The gknautomotive.com online catalogue lists OEM part number 1J0511115AF as being suitable for the Skoda Octavia MK1 1.9SDI estate heavy duty rear springs
Quantity 2
Thickness 11,25 mm
Length 352 mm
Weight 1,70 kg
white violent dots?
op best be careful when changing them, in case he triggers them ;)
just lol-ing at a (possibly autocorrect) typo...
if you are looking at them, bilstein b4 series shocks are available to match the various setups/loadings. b6 is the "sportier" version ie stiffer.
Thanks for the replys guys. Mac could do with maybe a bit stiffer but don't want it any lower will the b6  springs be the same ride height cheers colin
B6 are Bilstein shock absorbers not Bilstein springs.
For the Skoda Octavia MK1 1.9TDI, Bilstein B6 shock absorbers are around £500 for a set of four. Bilstein B4 shock absorbers for the same car are around £150 for a set of four.
Edited by Carlston
