Turbo Protection Device?
Folks,
I seen this guy outside my office today with a Scooby and was a bit surprised to see him walk away from his car with it running and no-one in it. :eek:
After about thirty seconds or so the car stopped though.
I have heard something recently about leaving turbo engines running for about thirty seconds after you stop the car .:rolleyes:
Just wondering if this car had some fancy turbo protection device that allows you to lock the car and then leave the engine running for a set time then switch off?
Does anyone on this site know of any such devices or the importance of leaving the engine ticking over for a while ?
Cheers :thumbup:
It's a turbo timer :D Available as part of some alarm systems. I wouldn't worry too much about letting the turbo cool down unless you've been doing hard driving and pull straight off the road (eg motorway into a services) where it won't do any harm to idle for 30 seconds.
Chris
I've been recommended to get one fitted - but I think the logistics of it are a nightmare.... So would rather just use common sense and if I've been boosting in the couple of minutes leading up to my destination, I'll hang fire in the car on tickover for a short while and then turn it off. :)
I've also read on here that turbo timers invalidate your insurance.
I'm having a coolant run on pump fitted with my latest upgrade which keeps the coolant circulating around the turbo after switching the engine off.
And, if you've parked-up on the road or anywhere open to the general public (e.g. Supermarket car-park) you risk being charged with 'Leaving your vehicle unattended (with the engine running)' (Not sure if that's the exact legal term, but you get the gist).
"QUITING" :D
its not so much the coolant round the turbo as more importantly the oil , this is what lubes the turbo bearings and if these aren't allowed to cool down after a hard run , i.e. turn engine straight off , the oil in the bearing will probably burn/dry out with consequential damage to bearings and seals eventually :eek: , thats why you leave the engine running at least 30 secs before turning off therefore allowing the turbo to cool down :thumbup:
Yeah that's true of the standard turbo that uses a journal bearing but not so important on ball bearing turbos. ;)
Anyway, I find the best thing is just to drive easy for the last few minutes of a journey.
Thanks for all the replies guys :thumbup:
Will try a conscious effort in the future to wait a bit before i turn my engine off
Once again thanks :orb_clap:
