Skoda superb TDI 2.0 2013 lumpy tick over
Good evening , i just wondered if anyone has had the same problem.I have a superb 2.0 Tdi 2013 with a lumpy tick over.
I have scanned it and it comes up with the code p1 06500.
Any help or advice would be appreciated.
Thanks Chris
p.s Reposting due to tying error
Yes fairly common issue on the cr engine. Will need a new fuel pressure reg on end of fuel rail.
Thanks for that rover220, i assume this the the type on mine
couldn't be sure but i suspect so.
You will need to reset the adaption values too.
It will still run lumpy once it’s replaced as the ecu is compensating still.
Hi and thanks for that, at the moment it’s going fine.
I know that fault has come but but i’m still unsure if it also has something to do with the dualmass flywheel and it knocked it out for a while.
I will keep an eye on it but thanks for your help 😬
