Does the vRS use different inner bearings?
To a TDI? :confused:
As far as I can tell all the models of Fabia with power steering use the same 72mm bearing: 6Q0 407 621 AJ.
Can someone confirm this please? I;ve had a new bearing go inside three months and one thing mentioned was the vRS uses a stronger inner bearing, and the one sent was for a TDI.... :confused:
Inner bearing?
Inner bearing?
inner peace? :rofl:
Well - bearing bearing thing - just wanted to distinguish it from the outer housing. Its technical name is "that bit in the middle that goes in the hole that the wheel bolts to and it goes round and round and round" :thumbup:
