Maxidot Secondary Speed Showing in Kph
How do you change secondary current speed on maxidot between dials from km to mph? PFL limited edition so basic bolero head unit
you need vcds and to change the area to Australia
But I don't live in Australia🤣
But that's the only way to get it to show. Although mine shows as MPH and it's a German spec car... but assume you'd rather not have your dash in German?! 😁😂
Edited by Phil-E
So, what its vcds, what does it do that any other professional automotive scan tool can't?
It can recode all of the vehicle electronic control units.
As said, you need to change the vehicle region to Australia, then in the maxidot menu you can disable "alt speed display" and enable "digital speed" which will give you a large digital MPH on the maxidot.
