Does anyone know what this wire is for
Hi all
A while back when changing front pads the plastic connector for the pad sensor broke where it slides in a bracket, I covered it with tape and all was done ok.
Yesterday 4 warning lights came on.
Abs, traction control, tyre pressure and a pic of steering wheel.
So wondering if I could change that wiring section that goes through wheel arch into engine compartment I removed battery etc and found a large harness that was rubbing on the battery tray, one wire look as though it was worn through but luckily not, it’s taped up now along with harness and moved slightly with some protection on it
( see pics )
So wondering if anyone knows what this wire is for ?
Also may be worth checking your own for same issue
Also still have fault and can’t change that cable as it goes into a large harness but checked out its ok
So going to get it scanned
Cheers, I know I may be asking the impossible
Edited by Snapper1725
On 02/09/2020 at 18:45, 26DIPP said:
I think this is your fog light supply.
Hi thanks for that, had been trying to find some info.
the wire is white/yellow with grey specs on.
This is a better picture of the wire, I tried to add this pic to my original post but couldn’t for some reason
