2007 PFL VRS with maxidot bluetooth retrofit
Hello,
ive got a 2007 PFL Octavia VRS with maxidot, it currently has a dreadful aftermarket head unit installed and i would like to swap it out for either a bolero or Columbus unit. I also would like to add Bluetooth functionality with audio streaming. Could anyone advise me on which Bluetooth module i would need for it to work correctly with the maxi dot and also the correct part number for the bolero or Columbus unit please.
I cant seem to find a correct answer on which module i need to work with the maxidot as there seems to be so many variants with different part numbers.
Thanks in advance
I can’t help with the Bolero part number but be aware that there are versions with and without mp3 capabilities from that age!
There are 2 decent brands,
FISCON has the 36494-6 series and DENSION a Gateway Pro model, all are factory integrated and show info in both screens.
Have in mind they are expensive.
You can check in their website.
