2010 Octavia electrical issues.
Hi all I am slowly working through the faults on my ex NHS Octavia estate. As some of you may remember I have had some serious problems with it but thankfully it now runs and drives fairly well.
Long story short the car died and would not start for love nor money the day after I got it home and spent 6 months with an auto electrician tracing faults before he finally discovered a broken wire between the fuse box and the engine ECU.
Unfortunately the car now has a number of faults it didn't have before it went some of which really should not have happened. For instance, the car was returned to me with a major oil leak because the rocker cover had not been tightened down and the intake pipe had been left disconnected from the manifold. I was also promised that the main beam headlights had been fixed and imagine my surprise when the first time I drove it after dark I had no main beam.
Most of the major issues have now been sorted but there are a number of faults that I would appreciate some advise on.
1) I have replaced the steering rack due to massive play in the original and have managed to get the the steering light on the dash to go out by calibrating the steering angle sensor in the steering assistance module using my OBD Eleven pro. However, I am still getting a code for no signal from steering angle sensor in the ABS module and as such the ASC light is illuminated. The code in the steering assistance module cleared and I can read live data for the steering angle sensor in the steering assistance module but not through the ABS module.
2) Main beam headlights do not work at all. The tell tale comes on the dash but the bulbs do not light up. I have replaced the bulbs to no avail. I have no voltage getting to the bulb so I suspect a wiring issue, is there any part of this circuit that is known to chafe? The auto electrician replaced the indicator stalk but this did not solve the problem and has also introduced others.
3) Cruise control no longer works and I am getting a code for missing signal from steering wheel electronics that apparently relates to it. This was working perfectly well on the old stalk.
4) Front fogs don't work and again there was no problem with these before the electrician had it.
5) Climatronic blower doesn't work.
6) Remote central locking is not working and I have only 1 key so cant use a second key to reprogram the key.
I know the auto electrician has replaced the body control unit and the indicator stalk as both originals were left in the car and I am getting fault codes for incorrectly coded modules.
I have just done a full system scan using OBD Eleven and include the report here.
OBDeleven data log
Date: 2020-09-12 14:14
    Car: Skoda Octavia
    Year: 2010
    Body type: Estate
    Engine: BKD 103 kW (140 HP) 2.0 l
    Mileage: 165390 KM
01 Engine
    Software number: 03G906021TC
    Software version: 2048
    Hardware number: 03G906021AN
    Coding: 0000072
    Trouble codes:
        P1699 - Databus drivetrain missing message from Steering Column Electronics
            static
                Priority:  3
                Frequency counter:  1
                Driving cycle: 255
                Mileage: 165391 km
03 Brakes
    System description: ESP MK60EC1
    Software number: 1K0907379AH
    Software version: 0107
    Hardware number: 1K0907379AH
    Hardware version: H30
    Long coding: 133B401C092300FFC80B02E9901F0082300000
    Trouble codes:
        00778 - Steering angle sensor No signal/communication
            static
                Priority:  2
                Driving cycle: 65
                Mileage: 165391 km
04 Steering Angle Sensor
    Trouble codes:
        No trouble codes found
08 Air Conditioning
    System description: Climatronic
    Software number: 3T0907044AR
    Software version: 0401
    Hardware number: 3T0907044AR
    Hardware version: H15
    ODX name: EV_Climatronic
    ODX version: A01006
    Long coding: 0000000002
    Trouble codes:
        B10BE07 - Fresh air blower, front mechanical malfunction
            static
                Date: 2113-12-09 14:11:46
                Mileage: 165391 km
                Priority: 2
                Malfunction frequency counter: 1
                Unlearning counter: 65
09 Central Electrics
    System description: BCM PQ35  B+
    Software number: 1K0937085D
    Software version: 0573
    Hardware number: 1K0937085D
    Hardware version: 103
    Long coding: 40180AB8B0050CB04010008011000024430000AE424D81605C4440000000
    Subsystems:
        System description: Wischer 24031
        Software number: 1Z2955119C
        Software version: 0601
        Hardware version: 22
        Long coding: 00D7B7
    Trouble codes:
        01503 - Bulb for high-mount brake light Open circuit/short circuit to B+
            Intermittent
                Priority:  1
                Driving cycle: 105
                Mileage: 165391 km
        01495 - Left high beam headlamp bulb Open circuit/short circuit to B+
            static
                Priority:  3
                Driving cycle: 65
                Mileage: 165391 km
        01499 - Right high beam headlamp bulb Open circuit/short circuit to B+
            static
                Priority:  3
                Driving cycle: 65
                Mileage: 165391 km
10 Parking Assistance
    System description: PARKHILFE 4K
    Software number: 1Z0919475B
    Software version: 0006
    Hardware number: 1Z0919475
    Hardware version: H06
    Serial number: 66641008910349
    Long coding: 100001
    Trouble codes:
15 Airbag
    Software number: 1K0909605T
    Software version: 2300
    Hardware number: 1K0909605T
    Hardware version: 003
    Serial number: 0038PD2KYYPZ
    Coding: 0020788
    Trouble codes:
16 Steering Column
    Software number: 1K0953549CQ
    Software version: 0111
    Hardware number: 1K0953549CQ
    Coding: 0000004
    Trouble codes:
        01044 - Control module incorrectly coded
            static
17 Dashboard
    System description: KOMBI
    Software number: 1Z0920903G
    Software version: 0305
    Hardware number: 1Z0920903G
    Serial number: 00000000000000
    ODX name: EV_Kombi_UDS_VDD_RM09
    ODX version: A04052
    Long coding: 410F00
    Trouble codes:
19 Gateway
    Software number: 1K0907530AD
    Software version: 0233
    Hardware number: 1K0907951
    Serial number: 4520K104070412
    Long coding: C9A07F06000202002303
    Trouble codes:
25 Immobilizer
    System description: IMMO
    Software number: 5K0953234
    Hardware number: 5K0953234
    ODX name: EV_Immo_UDS_VDD_RM09
    ODX version: A03005
    Long coding: 000000
    Trouble codes:
42 Driver Door
    Software number: 1T0959701AA
    Software version: 2114
    Hardware number: 1T0959701AA
    Coding: 0000758
    Trouble codes:
44 Steering Assistance
    Software number: 1K0909144R
    Software version: 3501
    Trouble codes:
46 Comfort System
    Trouble codes:
52 Passenger Door
    Software number: 1T0959702S
    Hardware number: 1T0959702S
    Coding: 0000758
    Trouble codes:
56 Radio
    System description: BOLERO
    Software number: 1Z0035156F
    Software version: 0053
    Hardware number: 1Z0035156F
    Hardware version: 010
    Serial number: SKZ1Z3K8444861
    Long coding: 0D0004000001
    Trouble codes:
        03138 - Input AUX IN Open circuit
            static
                Priority:  5
                Driving cycle: 65
                Mileage: 165391 km
62 Rear Left Door
    Software number: 5K0959703A
    Software version: 2101
    Hardware number: 5K0959703A
    Coding: 0000144
    Trouble codes:
72 Rear Right Door
    Software number: 5K0959704A
    Hardware number: 5K0959704A
    Coding: 0000144
    Trouble codes:
I'd probably start by putting the original BCM and steering control modules back in.
1) I think there is an adaption channel to specify where the steering angle sensor is, possibly in 03 ABS or 44 steering assistance.
2) I'd agree it's likely wiring given the tell tail works. Check T52aa/5 and T52ac/46 on the BCM go the left and right main beam bulbs.
3) The 16 steering controller coding is definitely wrong, maybe try 0000034 as that might get CC back - the ABS issue could also cause this.
4) This is down to the 09 BCM coding, byte 14, bit 0 should be 1 to enable front fogs.
5) Check the blower fan is free to move?
6) You need to pair both remotes. VCDS can do this but not sure about OBDeleven.
Thanks any idea what channel number that would be for steering angle adaptation? The only warning light for this showing is the ASC light. Steering wheel light was on but successfully cleared after doing the basic settings procedure in the steering assist module. Through the steering assist module live data I can pick up a steering angle sensor reading if I try and read through the abs module it reads zero regardless if steering wheel position.
As far as the other faults go I have changed byte 14 in BCM coding to 1 and OBDeleven now reads front fogs as fitted although they still don’t work.
Steering column module will not recode. I go into coding it will allow me to enter a new code to write but as soon as you try to write it it the software says function unavailable.
Blower fan is seized solid and unfortunately I only have one key.
Your main beam problem may be due to incorrect rewiring. In NHS use it may have had the lights wired to another unit to give alternate flashing headlights. In which case you need to connect the lights to the original lighting wiring from the on-board power control unit (early models) or equivalent on face-lift models.
In the same vein,  03138 - Input AUX IN Open circuit may be because the radio aux input was connected to a 2 way radio transceiver and the original wiring to the aux input was not reconnected.
Fault  01503 - Bulb for high-mount brake light Open circuit/short circuit to B+  similarly may be due to its use for other purposes in the past such flashing with the "blues and twos". Check wiring.
    Long coding: 100001
    Trouble codes:
Hi - don't want to highjack your post so I have sent you a PM with a question about this. :)
Problems now all solved.
Main beam issue was caused by original wiring from the BCU multiplugs having been disconnected and the same pin having been wired to a no longer existent control unit for flashing with blue lights. Thankfully the original wiring was still present, so just a matter of reconnecting the wire as per the wiring diagrams and we have main beams again.
Problem with the ASC light was because I have an MK60EC1 ABS unit and in 44 Steering Assist the steering angle sensor inside the rack was adapted active. Once I turned that off the ABS module starting picking up it's signal from the sensor behind the steering wheel and all warning lights are now off.
I am pleased that your persistance has paid off, it must feel rewarding.
