ABS module replacement
Hi all,
Since I need to replace my ABS module/pump on my Yeti, and I will probably try with fitting used one, do I just need to get the part that has the same modul number  1K0907379AJ, and get it coded afterward?
Or I have to get the abs module/pump where pump part also has same number?
Ok. So I have found same abs modul. Got it on thursday. Today, I started this morning with work to change module.
I needed to put jack under motor, I needed to unbolt right and central engine mount in order to be able to get DPF off, and have more access to abs module.
Then I unscrewed abs module, got it off, then putted the used one I got on friday, got DPF on again. And reverse procedure.
That change of abs module took me 4 hours.
Now I have to do coding, adaptation, abs bleeding and steering assist calibration.
Can you let me know the ABS Bleed procedure. I have VCDS and I've done it both on a Roomster and Fabia. On them it was open both fronts, close, open both rears etc.  I'm just wondering if it's the same.  Also can you confirm the Group number that you go into on the ABS to activate the procedure.
Yes. That is correct for bleeding procedure. It is same.
You can see the all procedure
He seems to just run the pump. I didn't do that, I did the ABS Bleed procedure where VCDS says open both front nipples, pump brake pedal 10 times, close fronts, open rears, pump pedal 10 times etc. I have actually tried that video idea of just running the pump, you can do it under basic settings, but it did not bleed the ABS of air. But the real procedure did, I think it was ABS Group 10 and Go to start it. But I can't remember 100% to be sure on the group number.
That is why I wondered if you could confirm the group number on the Yeti for the ABS Bleed as it does seem to change sometimes.
Group is same.
Group number 10 for bleeding
Group number 25 for adaptation
