Virtual Cockpit retrofit
10 hours ago, Hxxkxxx said:
(I belive it’s the mini facelift version)
I have no idea what you mean by this, what is the build date of your car? or if you dont have it, what is the VIN?
You need to know if you have 5A or 5C immobiliser which will vary the instrument cluster required.
  • Replies 56
  • Views 54.4k
  • Hello  Finaly i have done it  with the help of Vagguide. https://m.facebook.com/vagguide/ My car is 2016 version , i had to change BCM and GATEWAY  so that everything was functional. I had t
Pretty late at night when I wrote this, my apologies! It’s a 2020 plate but registered in 2021. Won’t seem to let me attach a pic so I’ll just send a link to a car that is the same set up as mine - https://www.carshop.co.uk/used-car/SKODA/SUPERB/OE70FZY (this is a petrol but mines a diesel).
This is what I’ve ordered https://www.ebay.co.uk/itm/195745960647?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=pnF0FLUNRUa&sssrc=4429486&ssuid=dl3v_jcati6&var=&widget_ver=artemis&media=COPY
I’ve got the MOST cable as well, so as long as I take it to my electrician (he can do all the specialist coding) I’m good to go?
The year its registered doesnt help with the build date necessarily, youll need to provide a VIN so i can find the build date and tell you if its compatible.
It is TMBKH7NP4M7043317. Thanks!
06.01.21 build date so it will be the 5C cluster, the one you have ordered is correct.
Thank you very much sir! It’s just with the electrician now, he’s waiting for access to code it in I think. Is there any tricks to get access granted if it gets denied?
If it’s a new cluster there is no requesting anything. Just use odis to disable cp and immo service mode.
