Steering angle sensor 00778
I have a problem With my skoda Octavia A5 2007 as the steering angel sensor changed twice and still the problem the same ..
steering angel sensor 00778 (G85)
so what’s the solution here ??
  • john999boy changed the title to Steering angle sensor 00778
Google it out and there is plenty info in the web from Ross-Tech, forums and YouTube videos.
Have you performed all basic  appropriate settings when replaced?
How I can perform the appropriate basic setting for this fault ??
Yes I have one .. I’ll try to coding it and if there’s some photos for code gonna be great .. thanks so much
Is there a communication between ABS control and steering angel sensor as I removed the abs and put it again
Is you get no any error codes for ABS, then it should be fine otherwise it should have dropped a message.
