P0321 Fault Code
Hi
I've experienced this whilst driving in 3rd gear trying to accelerate over 5000rpm, however it wont go past 5000rpm and i tried the same in 4th.
After looking at the forum, i couldn't find anything substantial however find a post on american forum describing the same symptons and the solutions seems to be replacing the crankshaft sensor.
I'll give an update once it done to see if its conclusion!
Any indication on the dash?
At first not but when I tried in 4th, the EPC lights and engine failure /workshop message came up.
I stopped the car and restarted and it was back to normal.
You should scan for fault codes to see but I suspect that sensor might be the cause..
Does anyone know where the G28 sensor is located on a CCZA engine? :sadsmile:
I think I need to take it to a garage as it would be easier to from underneath.
Edited by Awesam
Added additional comment
