Auxiliary lights, where to connect signal?
So, LED bar is mounted, Deutch relay cable kit fitted.
For running the signal to the relay, what is the most convenient place to
connect?
Okay... Seemingly the connector for the LHS headlamp would be the shortest route, but how the heck to loosen the connector properly? Plastic is a bit more fragile nowadays...
Or is it a better alternative to fetch the signal from the steering column harness ?
