ABS Module Retrofit
Hey guys,
I have Skoda Octavia Mk II 2009 1.9 TDI.
I have issue with the abs control module which needs to be replaced. The current model is 1K0 907 379 AD.
I couldn't find replacement in the market. What other models that are replaceable by that module and compatible with my car?
I'd suggest getting the same module if possible, saves any chance of incompatibility.
Otherwise, I'd look to get one with the same PR-codes, there is a list of MK60EC1 modules here:
Just make sure you backup the existing coding from your ABS module as it'll make coding the new one much easier.
2 minutes ago, Nasr said:
Thank you very much for your reply
In order to make sure I understood well, should I look for modules with same "PR-1AT "?
Could you give me examples by making them bold font please?
1K0-907-37?-AD ; MK60EC1 (PR-1AT
, UG0/UG3)
1K0-907-37?-AE ; MK60EC1 (PR-1AT, UG1/UG4)
1K0-907-37?-AF ; MK70M (PR-1AC)
1K0-907-37?-AH ; MK60EC1 (PR-1AT)
1K0-907-37?-AJ ; MK60EC1 (PR-1AT, UG1/UG4)
1K0-907-37?-AK ; MK70M (PR-1AC)
1K0-907-37?-AM ; MK60EC1 (PR-1AT)
1K0-907-37?-AN ; MK60EC1 (PR-1AT, UG0/UG3)
1K0-907-37?-AP ; MK60EC1 (PR-1AT, UG1/UG4)
1K0-907-37?-AQ ; MK70M (PR-1AC)
1K0-907-37?-AS ; MK60EC1 (PR-1AT)
1K0-907-37?-AT ; MK60EC1 (PR-1AT, UG1/UG4)
1K0-907-37?-BA ; MK60EC1 (PR-1AT)
1K0-907-37?-BB ; MK60EC1 (PR-1AT)
1K0-907-37?-BC ; MK60EC1 (PR-1AT, UG1/UG4)
1K0-907-37?-BD ; MK60EC1 (PR-1AT, UG0/UG3)
1K0-907-37?-BE ; MK60EC1 (PR-1AT, UG1/UG4)
1K0-907-37?-BF ; MK60EC1 (PR-1AT)
1K0-907-37?-BG ; MK60EC1 (PR-1AT, UG1/UG4)
1K0-907-37?-BH ; MK60EC1 (PR-1AT, UG0/UG3)
1K0-907-37?-BJ ; MK60EC1 (PR-1AT, UG1/UG4)
1K0-907-37?-BK ; MK60EC1 (PR-1AT, UG0/UG3)
1K0-907-37?-BL ; MK60EC1 (PR-1AT, UG1/UG4
At a guess, any module that says (PR-1AT, UG0/UG3) next to it should be fine.
Newer modules may have longer lcodes which is why I would stick to what's fitted...
You should check by asking someone with access to a parts database what's correct for you vehicle as I'm not 100% sure :)
The cheapest 1K0 907 379 AD modules on the bay come used from Europe at less than £120 including shipping and have 2 year warranties.
I doubt you'd get a UK reconditioning service for less.
