Couple Issues
Hello All
First is a sound that is an ongoing issue is a buzzing noise on the right side of the car. It buzzes even when sound is off and  windows or rolled up/down. It’s constant.
Second, today  when I was driving the car felt a bit off. When I arrived home and shut it down I could hear a fan running near the front/engine. I think the DPF must have been running but this is my first diesel. Did I do something really bad by shutting off during a DPF burn? What should I do now?
I'm obviously pretty much a novice when it comes to cars and car problems so any advice would be greatly appreciated. I've also noticed a noise when removing the key from the ignition after shutting off. It's coming from the engine area and it's like a couple clicks and a whirring noise. Not sure if this is normal but I've just now noticed it after 8 months of driving.
Thanks in advance!
Yes sounds normal.
You can also here similar sounds when you first unlock / open the car and when you turn the ignition on.
Buzzing noise might be a fuel pump?
Thanks, AG Falco
29 minutes ago, AGFalco said:
Yes sounds normal.
Thanks, AG Falco
it’s more of an electric buzzing coming from the right side of the car.
My Fabia is noisy after a run and the cooling water continues to circulate as it cools down.
Yours is a similar car?
Edited by gumdrop
