Fabia interior light stays on
if it thas expensive ill rather let it go for now :(
as i investigated the speaker wiring,i have noticed that the rear speakers are missing..i tought that the minimal factory specification had to conain it but it seems not :(
im planning  to fit the rears,can you help me where is the factory wire routed?
  • Replies 63
  • Views 10.8k
  • The interior light 'controlled ground' connection is done by this device, I've just seen: Datasheet here: http://www.farnell.com/datasheets/1651292.pdf   Can be just on/off in ter
On 17/11/2020 at 09:54, Wino said:
Probably, I have a new one at home I can measure for comparison; if I can find it...
Found and measured at 3.1 Ohms. Genuine new speaker.
On 17/11/2020 at 18:17, Alext said:
To fit the rears, can you help me where is the factory wire routed?
It isn’t. No factory speakers, no factory wiring.
i know :) i want to know where to route the new cable :)
does anyone know where to route the cables to to rear speakers?
also i found a lock cylinder for my door on flea market which advertised as for octavia 2.it looks the same as in my fabia 1.does the lock compatible?
Just run them down each cill under the carpet.
does it the proper way? i tought that there is a dedicated duct somewhere
There is no dedicated duct.
i see.thanks
how aout the lock cylinder?
does the 2006 fabia and 2008 octavia cylinder compatible?
Sorry, I don't know. Someone else may know.
If you look at this stripped-out Fabia (owned by member Tech1e) you can see the car's original wiring running down each sill. The main harness goes along the right-hand side....
IMG-8195-thumb-JPG-71dffbd1f4d3b80b083ee
Edited by TMB
thanks.my original idea was to route the wires back at the middle then split at the back but maybe ill run the wires at the side
anyone?
