Fuel pump, petrol
The fuel pump has become noticeably noisy, how long before failure do you reckon?
When I bought the car I thought the wheel bearing was slightly noisy, garage said not to worry but carry on until it got really noisy, 25,000 miles later it's not got any worse.
Should I change the pump, there are some cheap units on eBay or s/h ones locally, it doesn't look to be a difficult job?
1.4 16v
Check that the filter screen on the pump isn't clogged first, then change the fuel filter itself, if the pump is still noisey then you can change it.
