Clutch
Hi all hope all is well
Just a quick one has im not good with cars but my clutch peddle on my Skoda fabia vrs has stuck down with no pressure at all any ideas before I burn it out haha
Had this issue many years ago and it was the clutch master cylinder had failed internally, it's a real pain of a job to change if you are big person with large hands, as most of the work has to be done wedged in the footwell try to get at it, I gave up and a small mate of mine managed to undo cylinder and pipe, pedal was also a pain to get off out of the way Skoda must have a special tool for pressing the pins in together on the pedal pivot to get it off out of the way otherwise you need 3 hands, did not have any fluid loss just no clutch, might be a lucky one and clevis pin /arm missing bolt but not usually that lucky
Had the same problem with my VW caddy 1.6 tdi as mick said was the master cylinder in the foot well and my clutch pedal was stuck to the floor also
