HELPPPPPP WHIT AFS DRIVING ME MAD.
OK guys this have driving me mad for some time , as  some of you might know i have ben having issues whit me Bi-xeons everything to dynamic headlight regulation to even the daytime running LEDs, all that is sorted now , just one issues i cant figuer out is :
I used the  obd eleven II
and got the following error :
55 Headlight Regulation
    System description: AFS-ECU
    Software number: 7P6907357A
    Software version: 0080
    Hardware number: 7P6907357A
    Hardware version: H07
    Serial number: --------------
    ODX name: EV_HeadlRegulVWAFSMQB
    ODX version: 001120
    Long coding: 03CA02003F000000
    Subsystems:
        System description: LeiMo links
        Software version: 0009
        Hardware version: H06
        Long coding: 3E0000
        System description: LeiMo rechts
        Long coding: 3E0000
    Trouble codes:
        C103415 - Left front level control system sensor Open circuit/short circuit to B+
            static
                Date: 2020-12-12 13:37:23
                Mileage: 219366 km
                Priority: 2
                Malfunction frequency counter: 63
                Unlearning counter: 43
I have brought the part nummber : 7P6907357D . now my qustion is where is this bugger located , great if you guys got pictuers or something that shows  location of this part . Thank you all =)
That looks like the suspension level sensor and it's wiring are are fault, not the AFS module.
I'd start by inspecting the level sensor on the front left suspension and it's wiring for damage :)
front left level sensor is ok and the wiring is fine :/. shouldn't  obd eleven  give error code on the wheelbase sensor if it was malfunctioning ?
do you know where the AFS is located ?
You should download the workshop manuals for your car from: https://erwin.skoda-auto.cz/erwin/showHome.do
Failing that, it'll probably be in a similar location to the MK7 Golf:
- http://www.vwgolf.org/overview_of_fitting_locations_v_control_units_front_of_lhd_vehicles-2675.html
- http://www.vwgolf.org/removing_and_installing_headlight_range_control_unit_j431_control_unit_for_cornering_light_and_headlight_range_control_j745_lhd_vehicles-2596.html
The error code you posted is pointing at the front level sensor...
I thought that was pretty clear from the description: Left front level control system sensor Open circuit/short circuit to B+
Thanks alot for cleryfing things for me. Il check the sensor again :) and post some more info when i look at IT tomorow :)
Also check inside the multiplug if its damp or has green corrosion build up on the plugs as I had an issue on my Oct 2 Xenons and water in plug was the issue.
  • 3 months later...
Did you get it found?
