Roomster Instrument Cluster Upgrade, ideas needed
Hi All,
It seems that despite replacing my fuel sender unit and pump my ongoing issues may have been caused by a dodgy Instrument Cluster.
No codes on vcds but its not showing correct fuel capacity in tank and the gauge is only dropping two bars from the top and sticking.
So, I think its time for a change.
Has anyone upgraded their instrument clusters and if so what units are compatible with a 2006 1.9pd model.
I was wondering if a maxidot would fit from a Fabia mk2 or later facelift model roomster.
Anyway over to you....
My 2007 Roomie Scout has a full maxidot screen as standard, part number as follows if it helps
5J0 920 940 C
Hi
Thanks for the information and part number. It good that there is a maxidot display pre facelift as I'd heard afterwards you'd need to change the fuel sender unit (apparently they changed the wiring).
I'll definitely consider it.
