Octavia Scout Mk3 Rear Suspension
On 07/04/2021 at 20:23, peter3197 said:
...instead of the standard springs on my 2016 1.4tsi combi?
You might have the following standard ride height rear springs:
5Q0511121AF (Standard Ride Height Octavia MK3 Estate Rear Springs
Wire Diameter: 11.25mm
Length: 341mm
Outer Diameter: 109mm
Weight: 1.75kg
Number of Coil Turns: 7.75
https://web.tecalliance.net/gkn/en/parts/1/87783/detail?query=5Q0511121AF&numberType=1&oe=5Q0511121AF&groups=188#@brc/search:Search%20by%20any%20number%205Q0511121AF;query:5Q0511121AF;groups:188;brands:1;page:0/detail:87783;brandId:1;articleNo:87783;query:5Q0511121AF;numberType:1;oe:5Q0511121AF;groups:188
To increase the rear ride height by 15mm change to the following 15mm increased ride height rear springs:
5Q0511121BE (15mm Increased Ride Height Octavia MK3 Estate Rear Springs)
Length: 356mm
Outer Diameter: 107mm
Weight: 1.75kg
https://web.tecalliance.net/gkn/en/parts/1/88024/detail?query=5Q0511121BE&numberType=1&oe=5Q0511121BE&groups=188#@brc/search:Search%20by%20any%20number%205Q0511121BE;query:5Q0511121BE;groups:188;brands:1;page:0/detail:88024;brandId:1;articleNo:88024;query:5Q0511121BE;numberType:1;oe:5Q0511121BE;groups:188
5Q0511121BE Suplex 30026
https://www.autodoc.co.uk/suplex/15518365
This is a very neat solution, as the specifications of the springs are identical, except for the 15mm increased uncompressed spring length of the increased ride height rear springs. The ride comfort will be exactly the same. You will now have 15mm more suspension travel. This could be useful if the standard suspension sometimes bottoms out, for example going over speed hump. Increased ride height isn't for everyone, because it raises the car's centre of gravity. However, SUVs are very popular and they also have a higher centre of gravity than standard road cars.
There's not much choice for 5Q0511121BE rear springs, although autodoc list Suplex 30026 that matches this OEM part number. Other brands are sometimes sold to replace more than one OEM number, so might not be a close match. Those one size fits all approach springs are best avoided if there's another alternative. Some brands hide the fact that they are using a one size fits all approach by listing just one OEM part number against each model number...but what they are doing is labelling the same spring using different model numbers....Caveat Emptor...as they say in Latin. These one size fits all brands, tend not to list the specification of each spring, such as wire thickness, length, outside diameter, etc.
There are 9 standard ride height Octavia MK3 rear springs listed on the Skoda online parts catalogue
1 5Q0511121AA coil spring
Model data: PR-1JA+0YA
(1) 5Q0511121AB coil spring
Model data: PR-1JA+0YB
(1) 5Q0511121AC coil spring
Model data: PR-1JA+0YC
(1) 5Q0511121AD coil spring
Model data: PR-1JA+0YD
(1) 5Q0511121AE coil spring
Model data: PR-1JA+0YE
(1) 5Q0511121AF coil spring
Model data: PR-1JA+0YF
(1) 5Q0511121AG coil spring
Model data: PR-1JA+0YG
(1) 5Q0511121AH coil spring
Model data: PR-1JA+0YH
(1) 5Q0511121AJ coil spring
Model data: PR-1JA+0YJ
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2016/drive_standart/753/hg_ug/511/subcategory/511000/part_id/0/lang/e
In some countries, new car buyers have a 15mm increased ride height option. In other countries (particularly those countries with poor roads and lots of potholes), the 15mm increased ride height will come as standard. So +15mm ride height, standard ride height, and -15mm (lowered suspension) options are all perfectly normal on VW group cars.
It's easier to change rear springs than front springs, so do them first. If all goes well, repeat the process on the front...again using suitable springs.
The Scout springs appear to heavier duty and much longer than the +15mm increased ride height springs. So it might not be a good idea to use Scout springs on the standard car. Besides, +15mm should be enough for most owners who want a small increase in ride height.
In the UK, there is a lot less choice (and sometimes higher prices) for increased ride height springs compared to standard ride height springs, so do check availability first before making a decision to go for increased ride height springs.
Edited by Carlston
  • Replies 132
  • Views 30.3k
  • To find out what springs were factory fitted, check the build codes or the coloured dots on the springs (if they are original).   For example, if you had build code PR-L30 or 1 grey do
  • Just as an update to my spring replacement last year: all good. Handling is great after 4 wheel alignment, sag has gone, and towing a caravan much improved. Brilliant advice on here as always. I’ll be
  • Long time since no update with my Scout chassis parts, but I ended up replacing all shocks and front springs in October 2023 after a clutch failure (was driven approx 270 000km at the time). Rear spri
To add to the above, 5Q0511121BD could be used instead of 5Q0511121BE
5Q0511121BD will give the same ride height as 5Q0511121BE but are about 5% softer, which would be ideal for the Octavia MK3 hatchback whereas the 5% harder 5Q0511121BE are better suited to the estate, or the hatchback with towbar. If you don't carry much weight in the estate, the hatchback version could also be used.
5Q0511121BD (15mm Increased Ride Height Octavia MK3 Hatchback Rear Springs)
Wire Diameter: 11mm
Length: 361mm
Outer Diameter: 106mm
Weight: 1.7kg
https://web.tecalliance.net/gkn/en/parts/1/87893/detail?query=5Q0511121BD&numberType=1&oe=5Q0511121BD&groups=188#@brc/search:Search%20by%20any%20number%205Q0511121BD;query:5Q0511121BD;groups:188;brands:1;page:0/detail:87893;brandId:1;articleNo:87893;query:5Q0511121BD;numberType:1;oe:5Q0511121BD;groups:188
The 5Q0511121BD Lesjofors 4285742 +15mm increased ride height rear springs are currently available on autodoc for under £60 for two including postage to the UK. This compares to over £100 for a pair of 5Q0511121BE Suplex 30026 +15mm increased ride height rear springs.
https://www.autodoc.co.uk/car-parts/oem/5q0511121bd?search=OEN+5Q0511121BD&supplier[0]=253&supplier[1]=32&supplier[2]=85&supplier[3]=246
https://www.autodoc.co.uk/car-parts/oem/5q0511121be?search=OEN+5Q0511121BE&supplier[0]=10708
Edited by Carlston
  • 8 months later...
Greetings to all from a new member in this community!
You Carlston are a real legend!
I tried to turn the internet upside down to find info about suitable rear springs and found very limited information until i found this post!
My 2017 Octavia vRS Estate 2.0 TDI 4x4 DSG (+DCC, so not -15mm or standard ride height, but in my understanding somewhere between them?) is sagging from rear end even from full gas tank and i was considering changing stiffer rear coil springs as i also tow sometimes trailers.
I think that 5Q0511121BE would be good for me as the scout spring might not fit to my car as it´s not estate? Other option i found would be "MAD V-199545" (an auxiliary coil spring inside the original spring), but this auxiliary spring might lift the ride height and overall feel too much...
Season 3 Reaction GIF by The Office
Actually now on second thought i'm not sure will this 5Q0511121BE fit my car as it´s 2.0TDI 4x4 DSG + DCC...
5Q0511121BE is for a front wheel drive car, not a 4x4. You need to use 4x4 springs, if you have a 4x4.
You can use 4x4 Scout springs if you want 15mm increased ride height, compared to standard ride height springs.
The VRS 4x4 will probably have 15mm lowered ride height, ie. sports suspension.
You have three choices of rear Scout springs. They will all give you about the same unladen ride height. The difference is in the compression rate. The 13.00mm version is about 8% stiffer than the 12.50mm version, and the 12.75mm version is about 4% stiffer than the 12.50mm version. As you are towing, I would go for either the 12.75mm or 13.00mm version.
Wire Diameter 12.50mm, Weight 2.45kg
1K0511115CR (from Octavia MK2 Scout)
5Q0511115AL (from Octavia MK3 Scout)
These two springs appear identical and interchangeable. The MK2 springs are sometime cheaper than the MK3 springs.
Wire Diameter 12.75mm, Weight 2.6kg
1K0511115CS (from Octavia MK2 Scout)
5Q0511115AM (from Octavia MK3 Scout)
These two springs appear identical and interchangeable. The MK2 springs are sometimes cheaper than the MK3 springs.
https://www.autodoc.co.uk/eibach/13828877
Wire Diameter 13.00mm, Weight 2.75kg
1K0511115CT (from Octavia MK2 Scout)
5Q0511115AN (from Octavia MK3 Scout)
https://www.autodoc.co.uk/eibach/13828886
Octavia MK2 4x4 Scout Rear Springs
(1) 1K0 511 115 CR coil spring
1 paint mark
2 paint marks
red
green
2 PR-1JB+0YK
(1) 1K0 511 115 CS coil spring
1 paint mark
3 paint marks
red
green
2 PR-1JB+0YL
(1) 1K0 511 115 CT coil spring
1 paint mark
1 paint mark
rear
red
brown
2 PR-1JB+0YM
https://skoda.7zap.com/en/cz/octavia/oct/2012-663/5/511-511012/
Octavia MK3 4x4 Scout Rear Springs
1 5Q0 511 115 AL coil spring   2 PR-1JB+0YC
(1) 5Q0 511 115 AM coil spring   2 PR-1JB,0YD
(1) 5Q0 511 115 AN coil spring   2 PR-1JB+0YE
https://skoda.7zap.com/en/cz/octavia/oct/2016-753/5/511-511010/
Edited by Carlston
1 paint mark
2 paint marks
red
green
2 PR-1JB+0YK
1 paint mark
3 paint marks
red
green
2 PR-1JB+0YL
1 paint mark
1 paint mark
rear
red
brown
2 PR-1JB+0YM
Again, ashtonshing information.
I found from some Skoda Info leaflet that DCC would drop -10mm from normal height.. Difficult.
So as a conclusion maybe Normal 4x4 springs would be enough "lift" to rear for me without Scouts extra height. Does transmission type matter for the springs?
My thoughts are that i could keep front as original, but to rear maybe those normal 4x4 springs would lift the rear for a little better posture? Are there many options as in "normal height 4x4" without lowering sport/Dcc springs or Scout extra height springs?
Normal driving situation is that i drive my car without passengers, full tank, about 30kg weight in the boot and towing is only few times per year.
I'm so thankful for your effort that i really don't find words good enough to describe your help and great information.
And i think i forgot to mention. I have Combi/Estate.
I was able to find these with my VIN:
0YG VWGROUP GKH Weight range 7 installation control only, no requirement forecast
1JN VWGROUP DFH Rear shock absorption
G15 VWGROUP DFV Shock absorption in front
L18 VWGROUP GKV Suspension range 18 installation control only, no requirement forecast
Normal 4x4 springs should be enough lift to the rear. Manual or automatic transmission usually makes a small difference to the front springs. It doesn't affect the rear springs.
Lesjofors 4295133 (OEM part number 5Q0511115H) rear springs. Standard ride height, 4x4, with towbar.
https://web.tecalliance.net/lesjofors/en/parts/175/4295133/detail?targetType=cars&targetId=59490&typeNumber=59490&targetCountry=AT&groups=188#@brc/brands:Car;targetType:cars/assem:SKODA%20OCTAVIA%20III%20Combi%20(5E5%2C%205E6)%202.0%20TDI%204x4;targetType:cars;targetId:59490;typeNumber:59490;targetCountry:AT/lnkparts:Coil%20Springs;targetType:cars;assemblyGroupId:100113;targetId:59490;typeNumber:59490;targetCountry:AT;groups:188;brands:175;page:0/detail:4295133;brandId:175;articleNo:4295133;targetType:cars;targetId:59490;typeNumber:59490;targetCountry:AT;groups:188
Lesjofors 4295133 are listed on ebay.de (the German version of ebay)
https://www.ebay.de/itm/312961507221?epid=15032759793&hash=item48ddf59f95:g:6I4AAOSwmU9eSbQ3
Edited by Carlston
8 minutes ago, Carlston said:
Okay.
If i found correctly, i have now these according to PR-codes:
coil spring
PR-1JN+0YG
2
This LH variant seems to be pretty rare because i don´t find much information about these from the web...
i didn´t find any dimensions, length etc...
But if these two Lesjofors springs will do the job, i´ll go with those! Thanks! :)
Thanks for a really good information on this thread Carlston and others :)
I am also looking for new springs and shocks to my MY16 Scout with 2.0TDI 150hp equipped with 6spd manual gearbox. With my VIN TMBLJ7NEXG0128781, I was able to identify that in front I have G09 + L31 combination of springs and shocks, and in rear 1JB + 0YC.
I am happy how my front handles, so I think I will stay with the original spring hardness, but for the rear I think the original spring is too soft, rear is sagging already with minimal load. Propably will source the AN listed springs (SACHS 992 103), as my original spring is the softest of these options.
My question is about the shocks, have you anybody found good aftermarket solutions for the Scout suspension? I think the original rear shock is 5E0513029C or 5E0513029D, and the front shock is 5Q0413023GB.
23 hours ago, AnteroFIN said:
...if these two Lesjofors 5Q0511115H springs will do the job, i´ll go with those! Thanks! :)
OEM part number 1K0511115BH could be used instead of 5Q0511115H as they appear to be the same springs.
1K0511115BH is from the Octavia MK2, whereas 5Q0511115H is from the Octavia MK3.
If you look on autodoc you will see that there is more choice for 1K0511115BH rear springs than 5Q0511115H rear springs.
1K0511115BH
https://www.autodoc.co.uk/car-parts/oem/1k0511115bh?search=OEN+1K0511115BH
KYB RA7103 1K0511115BH
https://www.ebay.co.uk/itm/234261311747?epid=25029981017&hash=item368b0ff103:g:LkkAAOSwQPthe9Vv
Edited by Carlston
1 paint mark
2 paint marks
red
green
2 PR-1JB+0YK
1 paint mark
3 paint marks
red
green
2 PR-1JB+0YL
1 paint mark
1 paint mark
rear
red
brown
2 PR-1JB+0YM
https://skoda.7zap.com/en/cz/octavia/oct/2016-753/5/511-511010/#1
1K0511115CR is the same as 5Q0511115AL
1K0511115CS is the same as 5Q0511115AM
1K0511115CT is the same as 5Q0511115AN
Octavia MK2 4x4 Scout rear springs are usually cheaper than Octavia MK3 4x4 Scout rear springs.
Here's proof that 1K0511115CS is interchangeable with 5Q0511115AM (notice these Kilen and Lesjofors springs are sold to replace both OEM part numbers)
https://www.autodoc.co.uk/car-parts/oem/1k0511115cs?search=OEN+1K0511115CS&supplier[0]=246&supplier[1]=253
KYB RH6426 1K0511115CT
https://www.ebay.co.uk/itm/174956646233?hash=item28bc3a8f59:g:lgIAAOSwljlhUrTF
There aren't many aftermarket shock absorbers sold to replace Scout shock absorbers.
Scout models use +15mm springs. Therefore you could use standard ride height shock absorbers, as +15mm isn't much for the standard shock absorbers to cope with.
Or use original Skoda Scout shock absorbers.
Below are your front and rear springs and shock absorbers, for your Octavia MK3 4x4 Scout.
5Q0411105HS front springs L31
(1) 5Q0 411 105 HS coil spring
1 paint mark
1 paint mark
grey
blue
2
PR-L31
https://skoda.7zap.com/en/cz/octavia/oct/2013-753/4/411-411030/
5Q0511115AL rear springs 1JB+0YC
5Q0413023GB front shock absorbers G09
(8) 5Q0 413 023 GB gas shock absorber 49,6MM 2 PR-G09
https://skoda.7zap.com/en/cz/octavia/oct/2013-753/4/411-411002/
5E0513029C rear shock absorbers 1JB+K8D
7 5E0 513 029 C gas shock absorber rear 2 PR-1JB+K8D
https://skoda.7zap.com/en/cz/octavia/oct/2016-753/5/511-511010/#7
Edited by Carlston
Thanks for the info,
I have now ordered the Sachs 992 103 springs, to get a bit more load capacity to the rear. I will also replace the rear shocks, I found oem shocks with reasonable price, so I will not try any aftermarket version. At first I will replace only the rear parts, as the front seems to be ok. I will ofcourse do the front as well, if it feels that it is not in pair with the rear after the new parts. The car has run a bit over 200K km so might be needed to the front also.
Depending a bit on the ride, I need to think if a 4-way alignment would be needed, as the ride height changes a bit (5mm difference in spring length). I have done it when purchased the car ca. 1,5 years a go and it is "perfect" now and was a good 100€ spent at the time. Thw winter tyres are not so precise what comes to the steering, so latest with summer tyres I will see the need for the alignment.
5mm difference in spring length is insignificant, bearing in mind that the same springs with the same OEM part numbers could vary by 10mm in length even if ordered from a Skoda dealer. Different batch, different factory, etc.
Also, the actual ride height will vary enormously depending on the load you are carrying...there will be much more than a 5mm difference in rear ride height between a lightly loaded car and a heavily loaded car.
For example, a car with just 1 or 2 front passenger may have the rear axle supporting 600kg...but a car with 2 or 3 rear passengers, all of their luggage, and maybe a caravan in tow could have the rear axle supporting 900kg...ie. a 50% increase. This is a big difference for the rear springs to cope with. The rear springs in a lightly loaded car could feel too hard, but when the car is fully loaded the same rear springs could feel too soft...such is the compromise of choosing suitable rear springs.
Edited by Carlston
On 04/04/2021 at 18:06, wallacebob said:
I ordered these :
Sachs 992103 matches OEM part number 5Q0511115AN
https://www.autodoc.co.uk/car-parts/oem/5q0511115an?search=OEN+5Q0511115AN&supplier[0]=32
and was very pleased with Autodoc service. Springs are to the spec discussed above. I fitted them last week, following the guides that are available on Youtube , etc. Just search for golf mk7 or all track. I did the job with axle stands and a trolley jack, and it was reasonable easy to get it all back together.  I recommend clean all the bolt threads before disassembly to ease things up.
The ride height is pretty similar un-loaded, but huge improvement when loaded - no sag. Definitely firmer on the rear, but I can tolerate that. I think handling is a bit sharper too, but I will get 4 wheel alignment done again soon to check things are OK. I still haven't towed yet, but I'm very pleased so far. For just over £100 it's great value too.
Many thanks for all the advice.
Just as an update to my spring replacement last year: all good. Handling is great after 4 wheel alignment, sag has gone, and towing a caravan much improved. Brilliant advice on here as always. I’ll be keeping my Scout for a few more years now!
Hello,
just found this topic by googling. I bought Octavia MK3 2.0 TDI -2015 with DSG yesterday and I find the suspension sagging awfully. So much so that I suspect someone has at some point changed new springs that are not specced to Scout. Both rear and front are sitting much lower than should. Therefore I think it makes no sense to try to interprit the colour codes from existing springs.
So I just tried to buy stock Scout springs. But jesus, is it a complicated task for such a common car. Luckily I found this topic.
So all in all, I would be very happy if someone could tell which kind of springs and shocks I should buy for this very vehicle, what are the options? Is DSG with same front springs and shocks as the manual version mentioned some posts earlier?
Thanks!
What are the pr codes for your car for suspension? There should be this sticker in the boot area or in the service manual (huoltokirja) where all these pr codes are listed. With those pr codes you will find the correct oem numbers from this topic.
With the same answer, I can also confirm that my spring install was a success without need to replace the shocks. Car handles now much better with and without load, compared to the old stock spring. I haven't had any need for the 4-way alignment so far.
Found the sticker from service manual. It says in front I have G10+L31 shock absorbers and springs. This leads me to conclusion that at least in this case DSG and manual share the same springs BUT DSG has different shocks. G09 shocks are listed as 5Q0413023GB with length 49,6mm and G10 is 5Q0413031FS with length 54,6mm. So DSG has taller shocks?
Weirdly there was no info about rear shocks and springs but one would assume the same that you have will fit. I will choose the stiffest springs anyways. Would hate to have it sagging when towing trailer.
Thanks!
Answering to my own question. According to the description from one spare part page, that measurement is the diameter of the shock. So DSG seems to have sturdier shocks.
7 hours ago, TTimo said:
...there was no info about rear springs and shocks...
Kilen and Lesjofors recommend 5Q0411105HR front springs and 5Q0511115AM rear springs for the Octavia MK3 Scout 2.0TDI 4x4 with manual gearbox.
Kilen and Lesjofors recommend 5Q0411105HS front springs and 5Q0511115AM rear springs for the Octavia MK3 Scout 2.0TDI 4x4 with DSG automatic gearbox.
The only rear shock absorber listed on the Skoda parts catalogue for the Octavia MK3 Scout is 5E0513029C.
Rear shock absorber 5E0513029C
Kilen online catalogue
https://www.kilensprings.com/springs-catalouges/onlinecatalogue.asp
Lesjofors online catalogue
https://www.lesjofors-automotive.com/springs-catalouges/onlinecatalogue.asp
Kilen and Lesjofors are the same springs made in the same factory in Sweden.
It may be best to purchase genuine Skoda shock absorbers for the Scout rather than aftermarket ones, as you may have difficulty finding increased ride height aftermarket shock absorbers. This is because aftermarket shock absorbers mainly cater for the standard ride height market.
Edited by Carlston
Thank you so much for this info! It seems there exists very little knowledge in internet about Scout suspension outside this forum, glad I found this thread.
  • 3 months later...
Hello, dear Carlston! I have not met the best specialist in Skoda suspension issues on the Internet. In addition, you somehow magically know how to find the information that even official Skoda dealers do not give)) Thank you very much for your work and knowledge.
I want to ask for your help in solving my problem. I have a 2018 Octavia Scout, 2.0 TDI, 135kW, AWD. For some reason, 5Q0411105HS springs are installed in front, although for the Scout, as far as I understand, a package for bad roads should be installed, that is, springs 5Q0411105KM, 5Q0411105KN and 5Q0411105KP. I want to increase the ground clearance of my car.
Hence the questions:
- will any of the last 3 springs fit my car;
- do you have data on the characteristics (length, overall diameter and wire diameter) for these springs;
- is it possible to install the package for bad roads provided for Audi (plastic spacers) to increase the ground clearance on my car.
Thanks in advance for your reply.
Octavia MK3 front springs
1 5Q0 411 105 GF coil spring
1 paint mark
1 paint mark
blue
orange
2
(1) 5Q0 411 105 GG coil spring
1 paint mark
1 paint mark
blue
red
2 PR-L02
(1) 5Q0 411 105 GH coil spring
1 paint mark
1 paint mark
blue
violet
2 PR-L03
(1) 5Q0 411 105 GJ coil spring
2 paint marks
blue 2 PR-L04
(1) 5Q0 411 105 GK coil spring
1 paint mark
1 paint mark
blue
green
2 PR-L05
(1) 5Q0 411 105 GL coil spring
1 paint mark
1 paint mark
blue
brown
2 PR-L06
(1) 5Q0 411 105 GM coil spring
1 paint mark
1 paint mark
blue
grey
2 PR-L07
(1) 5Q0 411 105 GN coil spring
1 paint mark
1 paint mark
green
white
2 PR-L08
(1) 5Q0 411 105 GP coil spring
1 paint mark
1 paint mark
green
yellow
2 PR-L09
(1) 5Q0 411 105 GQ coil spring
1 paint mark
1 paint mark
green
orange
2 PR-L10
(1) 5Q0 411 105 GS coil spring
1 paint mark
1 paint mark
green
violet
2 PR-L12
(1) 5Q0 411 105 GT coil spring
1 paint mark
1 paint mark
green
blue
2 PR-L13
(1) 5Q0 411 105 HA coil spring
2 paint marks
green 2 PR-L14
(1) 5Q0 411 105 HB coil spring
1 paint mark
1 paint mark
green
brown
2 PR-L15
(1) 5Q0 411 105 HC coil spring
1 paint mark
1 paint mark
green
grey
2 PR-L16
(1) 5Q0 411 105 HD coil spring
1 paint mark
1 paint mark
brown
white
2 PR-L17
(1) 5Q0 411 105 HE coil spring
1 paint mark
1 paint mark
brown
yellow
2 PR-L18
(1) 5Q0 411 105 HF coil spring
1 paint mark
1 paint mark
brown
orange
2 PR-L19
(1) 5Q0 411 105 HG coil spring
1 paint mark
1 paint mark
  2 PR-L20
(1) 5Q0 411 105 HJ coil spring
1 paint mark
1 paint mark
blue
brown
2 PR-L23
(1) 5Q0 411 105 HK coil spring
1 paint mark
1 paint mark
brown
green
2 PR-L24
(1) 5Q0 411 105 HL coil spring
2 paint marks
brown 2 PR-L25
(1) 5Q0 411 105 HM coil spring
1 paint mark
1 paint mark
brown
grey
2 PR-L26
(1) 5Q0 411 105 HN coil spring
1 paint mark
1 paint mark
grey
yellow
2 PR-L27
(1) 5Q0 411 105 HP coil spring
1 paint mark
1 paint mark
grey
orange
2 PR-L28
(1) 5Q0 411 105 HQ coil spring
1 paint mark
1 paint mark
grey
red
2 PR-L29
(1) 5Q0 411 105 HR coil spring
1 paint mark
1 paint mark
grey
violet
2 PR-L30
1 paint mark
1 paint mark
grey
blue
2 PR-L31
(1) 5Q0 411 105 HT coil spring
1 paint mark
1 paint mark
grey
green
2 PR-L32
(1) 5Q0 411 105 KM coil spring
1 paint mark
1 paint mark
1 paint mark
white
orange
green
2 PR-L33
(1) 5Q0 411 105 KN coil spring
1 paint mark
1 paint mark
1 paint mark
white
orange
brown
2 PR-L34
(1) 5Q0 411 105 KP coil spring
1 paint mark
1 paint mark
1 paint mark
white
orange
grey
2 PR-L35
https://skoda.7zap.com/en/cz/octavia/oct/2016-753/4/411-411030/
5Q0411105HS PR-L31
1 paint mark
1 paint mark
grey
blue
2 PR-L31
Length 326mm, Diameter 152mm, Weight 2.05kg, Wire Diameter 13.00mm
5Q0411105HS looks like a Scout front spring, as it's considerably longer and heavier than many of the other front springs on the Octavia MK3.
There don't appear to be any aftermarket springs matching OEM part numbers 5Q0411105KM, 5Q0411105KN and 5Q0411105KP. However, on the chart above you can see that they correspond to build codes L33, L34, and L35, respectively.
Your build codes would confirm what type of suspension the car left the factory with. The chart below shows that build code 2UB = Rough-road design, and build code 2UF = Chassis with increased ride height.
VW Codes Decoder
2UA = Standard design
2UC = Sports version
http://igorweb.org/equidec.aspx
Edited by Carlston
It turns out somehow strange: there are springs (L33-L35), but they have no characteristics. So I should buy without looking?)
