Brakes on mk2 fabia
I want to go from standard 256mm to 288mm I know I need hubs and carriers can I fit them off a mk1 vrs on to a 1.2 mk2 and does it make a difference if there off a diesel 1.9
If you have build code 1LB or 1LM you will have 239mm diameter front discs.
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/FAB/year/2010/drive_standart/608/hg_ug/615/subcategory/615015/part_id/2550123/lang/e
However, it would appear that from year 2011 the 239mm diameter front discs were no longer an option on the Fabia with 256mm becoming the minimum size.
What option code do you have for your front brakes?
Edited by Carlston
I do have 256mm on atm but the carriers were cross threaded on to the hub and need new hubs. So good excuse to go bigger anyway
