Help Its Hot
Hi its hot today and Ive just discoverd my climate control is not working, well its not getting cold. 1.9 4x4 March reg just 2000 miles to date, my local dealer can`t take a look till Monday, any ideas what the problem could be ? Thanks Bill :confused:
I'd go to the showroom first thing tomorrow morning and shout a lot. I'm sure they will fit you in then.
Failing that see if a fuse has blown.
You haven't by any chance got the "econ" light on, have you? If so it won't go below the outside temperature.
Yep, make sure auto light is on and eco light is off, don't use the middle hot/cold kn0b. Use the right hand one to adjust temp, all the way down to LO if necessary.
Had mine set to17 today and had to turn it up as I was starting to freeze! The outside temp was 25!!
Did they manage to sort it out mate ?
I'm the guy you sat next to in the waiting area ;)
Hi still waiting. They said at Rainworth it needed a part and had to be orderd, still waiting its not in stock and on back order.So Iwent to Notts Dealer for a second opinion,they said it didnt need apart but would need farther investigation, Its booked in for the 5th june . Getting Mad.:( Bill
